alt should mount off the drivers exhaust manifold on that offset bracket - the single hole on the slotted piece will fit on one of the waterpump mounting bolts, usually w/ a bolt that has a nut an inch from the end rather than a regular head - the bolt holds the pump, bracket fits on the threaded end left exposed, held on w/ a nut - the slotted part attaches to the top of the alt and is the adjustment to tension the belt
not great pics, but like this and like this
