| | | Forums66 Topics128,046 Posts1,055,618 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20208 12/09/2003 3:44 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Depending on what year of truck you have installed the 235 you probably will have to use a electric fan,I installed a 57 235 in a 37 and the pulley just cleared the radiator and if a fan would of cleared the radiator it would hit the crank pulley. The perfect motor to use is the late 53 or 1954 235 as it has the same waterpump as a 216,I had the chance to buy a 54 before I found the 57 and I wish I would of gotten it instead of the 57. | | |
