What ever you do don't use WD-40 to lube the cable it will attract every speck of dust and gum the cable up quickly. The WD stands for water displacement formula 40. A dry lube like graphite is the best. It is also not effected by the cold. Not that I worry too much here in So. Calif. but in N. Dakota it could be a problem. Best of luck.
