twe56: The way I like doing it is get a good heavy chain pull your 4 corner bolts. Put bolts back thru chain links at each corner. Leave enough slack to join the 2 loops of chain in center with hoist hook. Had 396 and Auto transmission fall on left hand because chain broke. popcorn the Truth is Out There (Safety first good thing ground was soft or hand would of been gone)
