1 members (klhansen),
158
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 39 Junior Member | | Junior Member Joined: Nov 2003 Posts: 39 | I probably not help with the torque ball install but maybe with the T5. Are you talking about the opening with the transfer case removed? If you do use the T5 with the transfer case removed you would have no opportunity to use a speedometer. The 4x4 tailhousing does not have a place to install a speedo cable, it is on the transfer case. On the 2wd the tailhousing does include the speedometer connection.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
