ysrjunkie: I measured from the block to the raditor and it is right at 5.75 in. To the end of the shaft on the pump it's about 5.25 in. So there's about a 1/4 in. between the blade and the radiator. Keep us posted. Good luck.
'54 3100-235-T5 trans-12 bolt 3:31
'68 Impala 307/350
'78 Sportster/Original owner
