| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 14 Junior Member | | Junior Member Joined: Dec 2005 Posts: 14 | I was told by a local mechanic who has a '66 that you can use parts from a '73-'87 full size truck/van if you change your upper ball joints to match the donor. He got his from a '78 van and took everything from the spindles out. I believe the '70 uses the same frame and suspension as the '64-'66 models. | | |
