2 members (DennisM, 1 invisible),
80
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19532 11/16/2003 3:53 PM | Joined: Oct 2003 Posts: 36 Junior Member | | Junior Member Joined: Oct 2003 Posts: 36 | I would not use a stock radiator for your 350. The biggest issue you will have is that the 350 operates at higher pressures than the original engine. Also, it may not be as efficient as the newer radiators. I put a 350 in my 1950 and used an aftermarket radiator designed to fit in the same slot. It bolted right to the original radiator frame support!
Richie West
