You are correct about the 5 X 4 3/4" pattern. I was interested in the (minimum) rim size that would clear the calipers. Cpp said caliper size was for the medium size GM (77 camaro). Rotor size was 71-79 camaro. Thanks in advance.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
