7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | Im also going to install a 54 235 into a 51 pickup.Am i corect that the 216 pump and fan will fit with proper clearence?
The 54 235 Chevy block used the same water pump as the 216. Its a bolt in application with no modifications . Installing a short shaft water pump on a 55-62 235 is a little trickier. Every one I have done have had their own unique problems. Best bet is to use the later [ late 50's] 4 bladed fan. These fans are just short enough to clear the harmonic balancer after installing the s.s water pump. I also like to lower the radiator in its saddle a few inches since the 55-62 s.s water pump raises the location of the fan blade in realition to the radiator. I have had the best success with installing a 48-54 GMC radiator in the Chevy trucks that have been converted to a later 235. The GMC radiator fits inside the original Chevy radiator saddle & allows a lot of adjustment of the fan blade to radiator clearance. You can use the big 2 ton GMC radiator & still have room to adjust the clearance between the core & fan blade. I also like the look of the goose neck filler of the GMC radiators. The GMC radiators also come stock with a built in relief valve on the upper tank. | | |
