| | | Forums66 Topics128,056 Posts1,055,796 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 1/2 inch is close. I would not recommend bending the fan blades, it's a good way to start cracks and break the blade at speed, which can kill someone if your hood is open when it happens.
Problem is with finding the right fan. Makes it tempting to use an electric or a flex fan. The flex uses a lot of horsepower, and you will probably have to machine your own adapter to fit the older (larger) shaft. I was able to get the fan that came with my'54 235, believe it was originally out of a car.
Fred 52 3600 69 C-10
