| | | Forums66 Topics128,012 Posts1,055,316 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19160 09/11/2002 7:56 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Where did you plug the vacuum line? on the dist. side or at the carb? (should be at the carb) . . Did you set the octane selector to zero,secure that bolt.There is a screw just under the main part of the dist. housing that needs to be loosened to adjust the timing.It is like a clamp around the distributor housing shaft.
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
