9 members (Hush, crenwelge, RoadsScholar, Gdads51, R&S 51 GMC, Otto Skorzeny, Hotrod Lincoln, Ponchogl, Gray_Ghost),
106
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | The ground lug can attach to any piece of sheet metal around the inner fender, radiator support, etc. While you're at it, run some fair-sized ground wires from the frame to the engine, and frame/body, etc. It's hard to have too many ground wires. Run the negative battery cable to the engine for good starter and ignition grounding, and then ground the frame and the body metal back to the engine or the battery with smaller wires. Jerry
