7 members (68ironhead, Nhluvstruck, Otto Skorzeny, treegrower, MickeyP, Peggy M, 55shaker),
58
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,015 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 30 Apprentice | | Apprentice Joined: May 2005 Posts: 30 | Could be a plugged fuel filter and/or line. When it starts to die, choke it and see. If it acts like it wants to keep running,probably fuel problem. A coil/condensor will work when cool and when it heats up it will stop firing. I would be led to believe that if you were having a vapor lock problem, it would be after the vehicle has been run for a while(not just warmed up) in very hot outside temps. You're in Tejas, so it could be true. Vapor lock occurs when the gas boils and turns to vapor. Motor won't run on vapor. Easy way to check is to wet a towel and wrap it around the fuel line with tape before you start it. If it still dies after warmup, replace the coil and/or condensor. | | | |
Entire Thread
'61 Warms Up, Won't Start
| Phillip | 08/15/2005 4:43 PM |
Re: '61 Warms Up, Won't Start
| Inky05 | 08/15/2005 4:56 PM |
| Cousin Willie | 08/15/2005 5:01 PM |
| Inky05 | 08/15/2005 5:05 PM |
| bluenwhitegokart | 08/15/2005 5:12 PM |
| Inky05 | 08/15/2005 5:20 PM |
| Fumblin46 | 08/15/2005 5:52 PM |
| acwhite | 08/15/2005 7:29 PM |
| k10 | 08/15/2005 10:50 PM |
| V6 jimmy | 08/16/2005 1:49 AM |
| ddweaver | 08/16/2005 2:21 AM |
| AD_Pickup | 08/16/2005 2:33 AM |
| Tab | 08/16/2005 3:05 AM |
| caroline's truck | 08/16/2005 3:13 AM |
| AD_Pickup | 08/16/2005 3:20 AM |
| 48bigtrucks | 08/16/2005 3:53 AM |
| AD_Pickup | 08/16/2005 4:12 AM |
| caroline's truck | 08/16/2005 4:20 AM |
| AD_Pickup | 08/16/2005 4:28 AM |
| atomarc | 08/16/2005 4:33 AM |
| shooper | 08/16/2005 7:08 AM |
| Inky05 | 08/16/2005 12:13 PM |
| joe5757 | 08/16/2005 9:22 PM |
| ttodd | 08/16/2005 9:31 PM |
| V6 jimmy | 08/17/2005 1:27 AM |
| fatweed | 08/17/2005 2:25 AM |
| bluenwhitegokart | 08/17/2005 7:46 PM |
| Phillip | 08/17/2005 8:06 PM |
| bluenwhitegokart | 08/18/2005 11:32 AM |
| dale937 | 08/18/2005 5:17 PM | |
