The rebuild kits come with bushings, bearings, gaskets, shims, sector adjusting screw, and sector shaft seal. The bushing installation is the most difficult part of this rebuild. It takes a bit of work to install them and then they need to be reamed to fit the sector shaft. If your current bushings are in good shape just leave them alone. Do a search on this subject it has been recently discussed at length.
Jim
