Ok, that is the open driveline model, if you don't want to loose the torque tube then you will want the closed driveline version, which is less desirable by most anyway and someone might even swap you for it. The bellhousing is separate from the transmission so you will not need it. If you put a want ad in the swap meet I'm sure someone can hook you up with a torque tube version.
Paint & Body Shop moderator
