Anyone know of a 5- or 6-lug axle that'll bolt up in place of a '41-'46 1/2-ton rear axle??? I found a 235 close by, with tranny, from a '59, so I know the enclosed driveline will go away. I've heard a S-10 rear is the same width. Anyone know for sure what will be the same, in terms of width???
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
