If you do a search on here you will find alot of info, you will need to fab some motor mounts, you will need to replace torque tube to open drive line, using a t5 you need to research clutch application and which tailshaft and gear ratio you want. Input spline's for a gm t5 are 14 or 26 tooth the 26 tooth coming from v8 application 14 are from 4 and 6 cyl and not as strong.
