| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | Gord, The top hinge strap can be welded and re-tapped if need be. I have a couple of extra hinges though if you need one. The other problem is a bit trickier to solve. The hinge basket in the door jam is not reproduced but I also have a couple of these saved from a previous donor. Try to run a regular size tap through it and see if that will work. If not you can jump up a size and try that. I think those are 3/8 threads. | | |
