| | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | I have two questions regarding the gauges in my truck.
I have a 55 2nd series and the gas gauge and the temp gauge do not work.
When I pulled the cluster, the temp gauge (which was actually missing) had a real hard thick line (not line a 16 or 18 ga wire), but a solid wire from the sender unit, and was not connected. I replaced the temp gauge and connected based on a wiring diagram that I had found on the internet. It immediately went to HOT when I attached the wires according to the diagram. (I had to wrap a pc of 18 ga wire to the solid pc and taped it together the best I could) The other lead went to the key switch. I reversed the connection to see if it made any difference and it did not work in that position at all. I have not tried it again. So... what is the deal with the big solid wire? Should I just replace it and the temp sending unit?
On the gas gauge, the tank was rusted out so I replace the tank which came with a built in fuel pump and sender unit as one. I cannot get the gauge to work and I have rewired everything the best that I know how and according to the diagram stated above.
What is the best way to check the gauges to see if they work properly?
Thanks for all the information.
Jeff | | | |
Entire Thread
Gauages don't work
| sport55 | 03/30/2005 12:29 AM | |
