Hi, I'm new to the board. I bought a 59 Apache/Napco and I'm looking for some info. The truck is in good shape, it runs, but the brakes don't work. No pressure at all. This is going to be my starting point. Does anyone know where I can get a service manual that will describe the bleeding process for this type of brake system. I have never worked with a master cylinder on the frame before. Also, I am not familar with the air filter setup on the this engine. It is the 235/6 . It has the pot type air cleaner with oil in the sump. Is there a good replacement for this or is this the preferred cleaner? Any help would be appreciated.
1959 Chevy Apache/Napco conversion
1959 Chevy Apache Stepside 4x4
2009 Chevy Silverado 2500HD Duramax/Allison LB Crew Cab
