| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Cast iron exhaust manifold can be repaired by broadcast heating the entire unit and brazing with an acetylene torch. An experienced welder at a local weld shop can do this repair with lasting results if it is done properly. Depending on the year and displacement of the motor you may be able to find an OEM replacement and/or one from a scrap yard. If you plan to have it brazed, it will have to be removed from the block for prep and heating. Good luck with your FXXX repairs. | | |
