| | | Forums66 Topics128,272 Posts1,058,316 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | On my 46 for the front I used Chassis Engineering 37 to 39 car brackets. All you really want are the brackets. The bottom is bolt in. The top one I cut 1 inch out of the middle and welded it back together. As the top bolt for the shock will hit the inner fender and this drops it below that. It bolts in where the lever action was. Then I got a set of short shocks from Pete and Jakes as I had put in monoleafs. You would just get a set the length you need. You don't need there bolt kit as I think the car frame was boxed and uses longer bolts. | | |
