7 members (Gdads51, JoeDude, frogfarmer, Jon G, Hotrod Lincoln, gswbbc, Bill Hanlon),
124
2
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Most mechanical tachometers are driven directly off the camshaft or an adaptor on the distributor. There is an adaptor that fits stovebolt engines which was made by Mallory.
Mechanical tachs work just like speedometers, although speedometers read 60 MPH at 1000 cable RPM. Your tach reads 2000 rpm at 1000 rpm cable, which means it was meant to be hooked to a camshaft or distributor, which rotates at half crank rpm. Most tachometers will work with a standard speedometer cable.
The tach on my bike runs through the cam cover to a gear on the camshaft. Most cars are off the distributor though.
