0 members (),
80
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17532 04/25/2002 1:11 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | Attach timing light to #1 spark plug wire. Run engine at ideling speed. Loosen distributor clamp and rotate distributor body until the steel ball on the flywheel lines up with the pointer on the flywheel housing. Tighten the distributor clamp. The timing hole is on the starter side of the flywheel.
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
