Look up front in the cast area around the pinion. There is usualy a plug right in the passenger side of the housing about level with the u-joint. Most like this are set up to fit the square end of a 3/8" ratchet into. I usualy use a short extension to get the ratchet head away from the housing and make it easier to spin.
