90w gear lube (usually marked "universal" or "multi-purpose") is specified for both your SM420 4 speed and Rockwell transfer case. That's another nice thing about our older trucks....90w is used in the transmission, transfer case, both axles, and the front axle joints. In the 70's they started the confusing habit of specifying 30w motor oil and ATF in some models.
