| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17257 12/30/2003 5:01 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | axe, I think you will find opinions on both sides of this question. The 235 uses a bypass filter which only filters about 25% of the oil. Some will say 25% is better than nothing so use one. Others will say it's not necessary, just change your oil regularly. I say do what makes you happy, either will work fine. George | | |
