Thanks guys.The truck is a 72 ford with a 390 with 90 thousand miles.I had the valve covers off before and was able to forse a wire rod through 3 of the 4 return holes in the heads.Im atempting to get it back on the road for my 16 year old son to drive.It smokes like a pig onse the head fills with oil.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are... My progress pics
