crabbjw,
do you have a dana 44 front axle or the older NAPCO axle with the drop out center section. I think you have the dana 44, and should go to your local parts store and do some digging. I went to Orelly's and bought a set of WARN's top of the line hubs for my 61 for under $150. Milemarker also has the same hubs. If your parts store doesn't have them, check JC Whitney or some place like that. Its basically the same hub used on many later Chevys, as well as a bunch of toyotas and probably fords. Check my webshots for pics and let me know how it goes. Unless you are going 100% original, you do not have to pay over $150!
"If the women don't find ya handsome, they should at least find ya handy!"
1961 Apache 20 4x4
http://community.webshots.com/album/97352016vHsKNP
