| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17018 03/17/2004 10:31 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | FYI. Starting in 1941, Chev inproved there steering box with the addition of the reciprocating ball design. It is a fairly easy swap and well worth it. 1937 used a key on the steering wheel and from 38 on they used splines so you would need to splice the two steering shafts together or use a later steering wheel. They bolt to the frame the same and use the same pitman arm.
See the USA in your vintage Chevrolet! My Blog | | |
