0 members (),
108
2
Mod | | | Forums66 Topics128,105 Posts1,056,539 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | some f**d senders read 70-10 ohms with 70 being empty and 10 full. This is a problem if you have a GM gage because it is backards. I used a F**d mustang tank and modified the sender by inverting it. I also added some resistors in parallel with the sending wire to compensate for higher resistance. Seems to work but isn't very accurate below 1/4 tank due to the nature of the changes.
'53 chevy 3/4 ton
