| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 144 Member | | Member Joined: Dec 2002 Posts: 144 | Hello! If you were to replace the old Brake System in your 37 or 46 which Company Brakes would you use? This would be for Disc Brakes. Since there are so many to use from.
Would you use the Bolt On System or Change totally to a 5 Lug at the same time ? I understand that you can use the old spindles as well.
I just want to get some Professional Opinions before doing any changing.
Thanks Classic Finn | | | |
Entire Thread
Disc Brake Kit
| Classic Finn | 04/10/2005 3:16 PM | |
