| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16809 01/18/2004 4:24 AM | Joined: Nov 2003 Posts: 39 Junior Member | | Junior Member Joined: Nov 2003 Posts: 39 | After the hangar bearing I would check the splined section of the rear driveshaft for wear or damage. Saw a big 4x4 worn there once that vibrated so bad that you couldn't read the instrument panel. But I think that wear in the splined area would be a long shot.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
