| | | Forums66 Topics128,052 Posts1,055,718 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16431 05/26/2004 2:04 PM | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The pinion angle can be adjusted by using a tapered shim between the spring perch and the spring. Most driveline shops or places that do heavy truck repair should have something that can be adapted to work. Be sure the weight of the vehicle is on the springs while you're checking the driveshaft angle, or you're likely to encounter problems with the angle changing once everything is in the running position with the wheels on the ground. If it's really way off, the only option is to cut and reweld, but you need to check everything out with things assembled before you start modifying again. Pinion angle problems will cause oddball vibrations, and short universal joint life unless they're corrected. Next time, clamp everything together before you weld, and mark the housing for the correct fit, then disassemble it and weld the spring perches to your marks. Jerry
