| | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Meredith55,
From whom did you buy the glovebox light? The one I got from Brother's did not have a bracket or instructions. If yours has a bracket, I could post here or mail you instructions (Jim Carter's and Chevy Duty's had instructions).
Are the "screw clips" attached to the govebox? If so, after you "bring the box toward the dash panel to allow the box to fit arround the lip of the opening", there should be screw holes in the dash opening that line up with the clip holes. I have a '54 which has a slightly different box but it should attach in a manner similar to yours.
Tim | | |
