| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | On my el camino I didn't need to (plenty of things to keep it in place). I can see how it would benefit though. Is there anything to tuck it up against? If so, you may be able to drop a piece of pinch weld in there.... I did that on the door posts with my tweed...
If you need to hem it - then MAKE DARN sure everything fits perfect before you hem - otherwise it will not line up correctly.
- Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
