November 16th 2026 First cold front of the season made work in the BillyBob shop pleasant for a change. Didn't even have to run the portable A/C box next to the workbench. Back to the spark plug wires. My magneto Kung Fu is not strong so I'm tip-toeing thru this unfamiliar territory. Cleared the Hank Lansenkamp workbench and laid out tools, including a Pertronix 8mm wire stripper and digital multi-meter to check continuity, to act as talismans and ward off Murphy.
[IMG]https://www.laroke.com/larryk4674/2026/ds111626am.jpg[/IMG]
Took the mocked up magneto cap and plug wires off the nailhead and turned the engine over two revolutions back to TDC on the compression stroke to see where the magneto rotor was and which direction it was traveling. Good so far. Screwed the pooch right off by taking the number one terminal screw completely out of the cap. Had a devil of a time getting it back in. Had to resort to small needle-nose vice-grips to get the little bugger started again. It was an epic struggle for a first timer. Magneto terminals 5,6,7 and 8 are deep in the cap and the 8mm wires are a tight fit, even with lubricant. Finally got continuity readings between all magneto terminals and plug terminals.
[IMG]https://www.laroke.com/larryk4674/2026/ds111626bm.jpg[/IMG]
Noticed when I was fighting the magneto cap that the center electrode was loose. Concerned, I dragged the Chevy magneto that came with the Latham supercharger out of hoarder's corner and pulled the cap. It is the same so I am relieved somewhat. Actually, the center electrode is backed by a spring which makes sense to me now since it contacts the rotor. Beer of the day is Great Raft Brewing's Southern Drawl Dry Hopped Pilsner. Background music was The Moody Blues Time Traveler box set.
[IMG]https://www.laroke.com/larryk4674/2026/ds111626cm.jpg[/IMG]
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
