Originally Posted by Rock49
Considering you are sleving the lifter bore, could you sleve for small block chevy lifters. Or would the difference between lifter OD and camshaft lobe width be an issue?
Chris
I prefer to stay a little closer to the stovebolt lifter diameter when possible. The Chevy V8 and MOPAR lifers are pretty similar in price, so I don't see any advantage in going to the smaller diameter. My original project was to run a roller cam in the stovebolt engine, and the MOPAR tie bar rollers have the right spacing to run in the stovebolt block. Then I ran into a brick wall, trying to find someone to grind a roller cam for the Chevy six. "The juice ain't worth the squeeze!"
