8 members (TUTS 59, Bill Hanlon, GMCJammer51, NJC, Wayne67vert, 2-Ton, 2 invisible),
80
3
Mod | | | Forums66 Topics128,263 Posts1,058,136 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,982 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,982 | Chevy has used 11/32 valve stems for at least 80 years and they use the same grooves so the keepers will work. Rock Auto has the keepers for about $1 each. Chev has used springs that were a little over 2" for the same time frame. The inline springs are just a little bigger in diameter than the V8. So just to be safe I would match the retainer with the springs. I'm not sure that it would make any difference, but it wouldn't hurt to match them. The retainers really don't wear out. Used ones will work just fine. | | |
