Jerry, Since you can take off the push rod panel on the side of the 235 a person could check there lifters to see if they are rotating. So If you see that one is stationary, what would be the fix/ what are the potential issues? Thank you. Chris
Rock49 aka C-Rodg work in progress 1956 Chevy 3100 261 engine
