2 members (Hush, klhansen),
168
3
Mod | | | Forums66 Topics128,247 Posts1,057,919 Members48,477 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,237 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,237 | Resurfacing a pressure plate won't necessarily fix it if the springs are shot. But those can probably be rebuilt. If you've got the whole thing, offer them that way. Dan, were you able to find a complete clutch cover assembly (what I usually call a pressure plate)? I may have found one rebuilt clutch kit for the 11-inch clutch, But it seems to have only 6 bolts for the cover.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | |
Entire Thread
235 Cylinder Head, etc. - updated with more pictures
| WICruiser | 10/22/2026 12:27 PM |
Re: 235 Cylinder Head, etc. - updated with more pictures
| Hotrod Lincoln | 10/22/2026 7:08 PM |
| WICruiser | 10/23/2026 12:38 PM |
| Hotrod Lincoln | 10/23/2026 4:02 PM |
| wilbur53 | 10/25/2026 9:32 AM |
| WICruiser | 10/25/2026 2:58 PM |
| Gdads51 | 10/25/2026 4:24 PM |
| WICruiser | 10/26/2026 12:33 PM |
| WICruiser | 11/02/2026 1:56 PM |
| Gdads51 | 11/02/2026 3:08 PM |
| klhansen | 11/02/2026 6:59 PM |
| WICruiser | 11/03/2026 1:08 PM |
| Gdads51 | 11/03/2026 5:48 PM |
| klhansen | 11/03/2026 5:47 PM |
| klhansen | 11/03/2026 5:51 PM |
| WICruiser | 11/03/2026 11:23 PM |
| Gdads51 | 11/03/2026 11:58 PM |
| klhansen | 11/04/2026 4:25 AM | |
