I installed one on my '54 235 engine, and it made a big difference vs the Fel-Pro manifold gasket.
Did you have a leak or a warpage problem prior to installing them?
yes, two previous fel-pro manifold gaskets never sealed fully (did the job twice over a couple years, not two stacked gaskets). I did not verify, but I suspect the manifolds were the issue.
