| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,899 | I weld up the shaft oversize, file and/or grind it square, and file the hole bigger to be a slip fit on the oversized shaft. Just a few thousandths is usually all that's needed. Jerry
