| | | Forums66 Topics128,233 Posts1,057,673 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 2,339 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,339 | I agree looks like a rebuildable engine ,You found were the head gasket was leaking ,looks like was leaking into the two cylinders a bit also .Most likely the oil may have been a head problem also .If you decide to take it apart for rebuild take lots of pictures and mark were everything came from. | | |
