2 members (Hush, klhansen),
168
3
Mod | | | Forums66 Topics128,247 Posts1,057,919 Members48,477 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 447 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 447 | Thanks Glen, cleaned it all up, turned out to be 7/16/18 and a 2.5” bolted flush through the two halves and added a new grease zerk. All is good with that now but now it appears the torque tube is sprung. Off about an inch from side to side where it hits the leaf springs. Not much in the manual but I loosened the 3 bolts to adjust but haven’t gotten any movement yet. Initial appearance the rear looks in pretty good shape. Replaced the outer bearings and seals. Passenger side was leaking onto the brake. Still had the leather seal. Also is the higher gear 3.82.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
