Finally putting the rear back together. New spring eye bolts and bushings, shackle kit. Question #1 - Per picture It appears to have bolts that must come from the bottom into the top of the upper half of the casting. When I took it apart, there wasn’t anything holding the two halves together and holes were plugged with grease/dirt. I’m assuming they must be important. Question #2 - I have not messed with the torque tube at all and hope I don’t have to, but how much slop/ fore and aft is in the driveshaft when measuring on the springs for final bolt down. Is it a spline shaft slip joint with leeway? From the wear marks on the springs I can say they weren’t even close to straight and there doesn’t appear to be any real alignment other than measurements and tightening as the casting has a pretty good sized slot. Loosen both sides, measure for evenness and tighten? And yes there another casting with ears for the U bolts to help mount the helper springs with other u bolts.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
