On my '46, the brake light switch is located on the firewall on the engine side of the brake pedal. My brake lights stopped working one time and the switch tested OK. My brake light wiring goes through my Signal-Stat 800 turn signal and I ended up taking it apart to spray all the contacts with electronic cleaner. After cleaning, my brake lights started working again and they are still working today.
~ John in Utah
1946 1/2Ton w/4-speed manual transmission w/1960 235 engine
Here We Go
Follow in his DITY Bay
- If you think about it, it has been one year ago today!
