| | | Forums66 Topics128,208 Posts1,057,448 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 272 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 272 | Both of these engines have oil gallies which are plugged on the outside of engine block (front and rear.) I’ve read reports that these plugs can leak or dislodge. There are recommendations to tap these ports and plug with pipe plugs. Is it recommended for the 216 and 235? | | |
