Winter is Coming
I have 1/4, 3/8. and 1/2 inch drive beam style torque wrenches, as well as a 1/2" clicker that has a higher capacity than the 1/2" beam style wrench. Use them all.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
